Display Menu IDs in positive numbers
Yaron
2014-01-15 01:29:28
How can I set Restorator to display Menu IDs in positive numbers?
Instead of:
MENUITEM "E&xit", -7871
Display:
MENUITEM "E&xit", 57665
Thank you.
2014-02-25 20:17:33
hi yaron, unfortunately that's not possible. You can just subtract the negative number from 65536 to get the positive value. Internally, they are equivalent.
Yaron
2014-02-26 02:48:59
Thanks for replying.
When localizing a program with an external file, subtracting the negative number from 65536 (for each string) is not convenient.
If you plan to update Restorator, please remember this issue. :)
Yaron
