Cham
2007-03-02 15:25:09
When I add resources using the command line they behave different from adding them through the ui.
I am adding an .bmp file with the following command line options:
-open visual.exe -assignOn Bitmap\324 herald.bmp -saveAs test9.exe -exit
When I look at the create test9.exe it has the bitmap but the type is "Bitmap image".
When I add the resource manually through the UI the type is "Bitmap".
When I use -open visual.exe -assignOn 2\324 herald.bmp -saveAs test9.exe -exit it works as expected.
Is this intended behavior or am I missing something.
Cham Püschel
Soops
Cham Püschel
Soops
