This application has failed to start because .dll was not...
ReaImDown
2007-06-11 00:42:21
This application has failed to start because .dll was not found. Re-installing the application may fix this problem.
I did the following,
Add Resource, language = english us (united kingdom)
id = 121
then added this code
121 DIALOG 0, 0, 200, 117
STYLE DS_SYSMODAL | DS_SETFONT | DS_MODALFRAME | DS_CENTER | DS_CENTERMOUSE | WS_POPUP | WS_VISIBLE | WS_CAPTION
CAPTION "Info"
FONT 8, "MS Sans Serif"
 DEFPUSHBUTTON "OK", 1001, 76, 94, 50, 14
 LTEXT " Randy Skinner", -1, 45, 13, 142, 9
 LTEXT "\r\nE-mail: diablo_rules78@hotmail.com\r\n\r\nWebsite, Coming Soon", -1, 7, 46, 186, 44, SS_SUNKEN | WS_BORDER | WS_THICKFRAME, WS_EX_DLGMODALFRAME
 CONTROL "", -1, "STATIC", SS_BLACKFRAME | SS_SUNKEN, 7, 34, 186, 2
 ICON 102, -1, 7, 7, 21, 20
2007-06-11 09:51:27
I could successfully do exactly what you described with e.g. Notepad and I did not encounter your error message. Which program are you trying to edit?
Note that some programs use their own CRC check to prevent such modifications.
ReaImDown
2007-06-11 14:17:05
heres the download
http://www.autoitscript.com/cgi-bin/get ... .2.4.9.zip
heres the file
extras\Exe2Aut\Exe2Aut.exe
ReaImDown
2007-06-12 02:28:56
lets try it this way, can you tell me how I would go about adding in a menu add-on with a pop up informational window?
2007-06-17 20:03:44
you cannot add a dialog that will be shown upon selecting a menu entry. That connection has to be done with program code...
Sorry,
