IncaDeCuzco
2007-10-18 03:46:58
I am not sure this type of question is appropriate here but anyway.
I have .dll file that has to be localized from English to Japanese. Everything has been going well so far, good job Restorator!
The new version of software I am working with came with new type of resource in .dll which is called BINARY. When you open Restorator and then folder BINARY of that .dll file, you will see 2 files: IDU_DEFAULT PALETTES.xml and IDU_XLS TEMPLATE.res. Both cannot be edited directly in Restorator.
Searching the WEB, I have found out that the .res file is actually used by the program and .xml file serves as a source or something for that file.
Question: Is there any way to modify that .res file? I could extract .xml open it with some other program and then try to convert to appropriate .res to compile back into existing .dll. (?)
Any help will be greatly appreciated. Or, if you consider this as a lack of skill rather than some issue concerning Restorator, just ignore this message. I am not a programmer.
Thanks.
Victor
Thanks.
Victor
