jonware
2007-12-02 19:09:51
After a windows reinstall, I have reinstalled the full version of Restorator build 1729. However I'm unable to patch this to build 1747 - running the patch executable gives firstly the error:
and then after clicking "OK", the error:
I was successfully able to use this patch file, last time around, but have redownloaded it (just in case it had somehow got corrupted) with the same results.
Thanks in advance for any help.
Jon
An error occured while loading the dll:Code: Select all
BTMemoryLoadLibary: Can't attach library
PatchBreeze Engine load error. Please report this to the authorThanks in advance for any help.
Jon
