A few things
Bruno
2005-05-21 11:01:08
I found a few bugs in Restorator 2005.
1. If I maximize a window the settings are not remembered after a restart. This is a bit annoying.
2. A lot of .res files doesn't properly show the dialogbox while other applications, like Resource Hacker, shows it correctly. Here's an example:
http://s4.yousendit.com/d.aspx?id=10695 ... QA6JPYMKMU
I hope you can fix it.
2005-05-22 14:51:01
I can reproduce both bugs. The latter is a missing feature. I've corrected bitmap display in dialogs for .exe/.dll files, but it's still due for .res files.
I'll post here once I have an update.
2005-05-22 15:19:25
Bruno wrote: 1. If I maximize a window the settings are not remembered after a restart. This is a bit annoying.
Fixed in build 1449 (and later).
totoymola
2005-05-23 06:26:26
When are you going to release that? :)
- Carlo T.
2005-05-23 09:04:30
We plan to release beta builds in irregular intervals for registered users, especially if something important (crash, etc.) comes up.
