waliedassar
2012-06-01 00:40:04
Version Affected: 3.70 Build 1747
1) A minor security issue when parsing .res files.
Demo:
http://www.4shared.com/file/yRtP77bP/Off_by_two.html
2) The size of the "IMAGE_OPTIONAL_HEADER" structure is assumed to be SizeOf(IMAGE_OPTIONAL_HEADER), 0xE0 in hex, while it can even be greater. Having the size to be of a greater value causes Restorator to discard the whole PE file.
Demo:
http://code.google.com/p/ollytlscatch/d ... x15DDs.exe
3) Restorator uses The "NumberOfRvaAndSizes" field, which can easily be forged to 0xFFFFFFFF. This causes Restorator to discard the whole PE file.
Demo:
http://code.google.com/p/ollytlscatch/d ... FFFFFF.exe
4) The section name can easily be changed from ".rsrc" to anything else. This causes Restorator to discard the whole PE.
Demo:
http://code.google.com/p/ollytlscatch/d ... o.rsrc.exe
5) Sections with the "Characteristics" field set to IMAGE_SCN_CNT_UNINITIALIZED_DATA among other characteristics are discarded by Restorator while parsed normally by PE loader.
Demo:
http://code.google.com/p/ollytlscatch/d ... IniSec.exe
N.B. Demo executables above are seen by Windows as valid ones.
Demo:
Demo:
Demo:
Demo:
Demo:
