Bad Dsiciple
2015-02-20 21:23:07
Hello,
I'm having a problem with dumping my drum machine Alesis SR18 memory to Bome SendSX1.40.
I correctly set "Opened MIDI IN" to my interface (TC Electronic Impact Twin) and it sees it.
I correctly do the simple procedure in the drum machine (SEND MIDI OUT in the System Setup, Page 17, Rec/Enter).
The drum machine sends it for a given time and after finishing, nothing happens in Bome SendSX1.40.
Nothing saved.
Why should a simple process such as saving my work be so complicated?
Do I need to become a molecular physician to be able to just save my music work in my PC?
Any help will be highly appreciated.
Thanks.
BD
Nothing saved.
Thanks.
BD
