Kaminari
2005-05-11 21:46:26
Hi Florian!
SendSX is the perfect SysEx monitor for my Roland CM-500. Thanks for this great utility -- postcard pending
I'm having a problem with 1.22 version. When I select my MIDI In and Out ports, they are saved in Registry after I quit SendSX; but when I run it again, In and Out ports are automatically reset to None, and I have to manually set them again (other settings like delay, window positions, etc are not affected). This is a minor issue but it's a bit frustrating after a while...
For the record, it works fine with 1.21 (which, I believe, uses a different set of Registry options). I'm under WinXP SP2.
Cheers,
Patrice
Cheers,
Patrice
