Fractal Audio Axe Fx ultra
chopshop777
2010-01-10 05:42:10
Does anyone here use the Axe Fx Ultra ? do you know how to update it using SendSX if you got a Mbox Pro 2 hooked up to it by way of MIDI cables ?
Cheers
Ed
ecovindaloo
2011-08-07 19:28:41
Are you able to do Sysex dumps with an Mbox? I'm using an Behringer FCB 1010 and I can't do sysex send or receives. I'm posted here and haven't gotten an answer yet and I looked online and can't find out either.
Any information you can provide me with would be great. Thanks.
2011-09-14 22:03:24
you should just try. In general, SendSX should work fine with all MIDI devices out there.
