Problem sending Fractal MFC firmware
m@
2010-11-11 17:43:26
Hello,
I've downloaded a Firmware (sysex) file from the Fractal site.
Midi Ox sends this file with no trouble and the unit updates successfully, but when I try with Bome's, the file APPEARS to send but the unit hangs at 0% on the update progress meter, needing to be rebooted to continue.
I'm wondering if it could be something in the file... or a bug in SendSX. Any thoughts?
http://www.fractalaudio.com/Documents/m ... 1_0.19.zip
PS: Someone else who is using Bome's asked me for help.
m@
2010-11-11 18:42:47
STRANGE!
If I record the output of SendSX into the midi input of a different computer, then save this as a file, then play this file back into the MFC with MIDI-OX, it works!
Only thing I can imagine is that SendSX might be handling the delays between messages irregularly?
2011-10-22 17:46:02
yes, you can configure the send speed in Send SX. (at least in the beta version).
