CreepyPants
2016-07-19 16:49:23
Okay, I've only used MTPro for some extremely basic processing in the past, but in prep for BomeBox I'm excited about the possibility of using a more complex script without a computer for performance & currently trying to design/code it.
However one nagging bit I have in the back of my head:
On the PC version of MTPro (licenced), I'm using ports specific to the PC which will not be available once I have a BomeBox in the rig.
That is:
PC SETUP -
[Controller] -> PC/UM-ONE MIDI to USB IN -> MTPro -> UM-ONE MIDI to USB OUT -> [Synth]
However, if BomeBox is supposed to allow me to load my MTPro translators from the PC, will there be a way to change the setup to
[Controller] -> BomeBox In -> [Translate] -> BomeBox Out -> [Synth]
Since labels/port definitions will effectively be changed, no?
That is:
PC SETUP -
