Can
2016-10-11 14:25:54
I've a question about a special usecase of the BomeBox that might be very interesting for every live keyboardist!
Some months ago I created a script for Mainstage that holds a chord (of course without sustain pedal) until the next chord is played. So I can press a chord, release the keys but the chord is sustained until I start playing a new chord. That's great for playing pads or strings while playing different melodies / solo on a different keyboard.
With my script I can stop the chord either with a certain keyswitch (this key won't be played then of course) or - what I prefer because I don't have to remember the keyswitch) - to release the chord by touching the pitchbend wheel.
With the modwheel I can switch on/off the chord hold mode (modwheel < 20 = chord hold, modwheel >= 20 = bypass/no chord hold).
Now I'm very insterested to know if the bomebox scripting can handle this more or less complex task. Would be great if there's a possibility!! My mainstage patch works well but I'd like to go without macbook to the stage and just having a robust little hardware like the BomeBox!
Best from Germany
Lukas
Best from Germany
Lukas
