DreamXcape
2016-10-19 17:48:21
Hello,
I have 4 Allen & Heath Xone 1D's and 2 Waldorf Blofelds and would like to connect them using the bomebox.
I want to remap the Xone 1D's so they can be used in FL Studio and also that they can be adressed as 1 device.
The Blofelds i just want to connect so they can be used both by 2 computers without disconnecting them every time.
I currently use a iConnectMIDI4+ and it only supports one of each device. As soon as you plug in another of the same device one of them will not be recognised. The rest of the devices I have to connect directly via USB.
The problem I'm facing is that Windows 7 likes to change the device numbers on reconnect sometimes, resulting in a non-working Midi Translator project. I can solve this by reassigning the aliases to the right devices but it's kind of a PITA to do this.
Same thing with the Blofelds, Windows 7 likes to swap them around sometimes.
So my question is: Does the BomeBox support multiples of the same device via USB-MIDI?
