Here is a list of what Windows winmm.dll returns. Would any of this naming cause a problem?
The following Autohotkey code segment was used to get this list. Although I did some post formatting of the output.
;--- MIDI INS LIST FUNCTIONS - port handling -----
MidiInsList(ByRef NumPorts)
{ ; Returns a "|"-separated list of midi output devices
local List, MidiInCaps, PortName, result
VarSetCapacity(MidiInCaps, 50, 0)
VarSetCapacity(PortName, 32) ; PortNameSize 32
NumPorts := DllCall("winmm.dll\midiInGetNumDevs") ; #midi output devices on system, First device ID = 0
Loop %NumPorts%
result := DllCall("winmm.dll\midiInGetDevCapsA", UInt,A_Index-1, UInt,&MidiInCaps, UInt,50, UInt)
If (result OR ErrorLevel) {
List .= "|-Error-"
Continue
DllCall("RtlMoveMemory", Str,PortName, UInt,&MidiInCaps+8, UInt,32) ; PortNameOffset 8, PortNameSize 32
List .= "|" PortName
;Msgbox Inports are %List%
Return SubStr(List,2)
MidiInGetNumDevs() { ; Get number of midi output devices on system, first device has an ID of 0
Return DllCall("winmm.dll\midiInGetNumDevs")
MidiInNameGet(uDeviceID = 0) { ; Get name of a midiOut device for a given ID
;MIDIOUTCAPS struct
; WORD wMid;
; WORD wPid;
; MMVERSION vDriverVersion;
; CHAR szPname[MAXPNAMELEN];
; WORD wTechnology;
; WORD wVoices;
; WORD wNotes;
; WORD wChannelMask;
; DWORD dwSupport;
VarSetCapacity(MidiInCaps, 50, 0) ; allows for szPname to be 32 bytes
OffsettoPortName := 8, PortNameSize := 32
result := DllCall("winmm.dll\midiInGetDevCapsA", UInt,uDeviceID, UInt,&MidiInCaps, UInt,50, UInt)
MsgBox Error %result% (ErrorLevel = %ErrorLevel%) in retrieving the name of midi Input %UDeviceID%
Return -1
VarSetCapacity(PortName, PortNameSize)
DllCall("RtlMoveMemory", Str,PortName, Uint,&MidiInCaps+OffsettoPortName, Uint,PortNameSize)
Return PortName
MidiInsEnumerate() { ; Returns number of midi output devices, creates global array MidiOutPortName with their names
local NumPorts, PortID
MidiInPortName =
NumPorts := MidiInGetNumDevs()
Loop %NumPorts% {
PortID := A_Index -1
MidiInPortName%PortID% := MidiInNameGet(PortID)
Return NumPorts
; =============== end of midi selection stuff
MidiOutsList(ByRef NumPorts)
local List, MidiOutCaps, PortName, result
VarSetCapacity(MidiOutCaps, 50, 0)
NumPorts := DllCall("winmm.dll\midiOutGetNumDevs") ; #midi output devices on system, First device ID = 0
Loop %NumPorts%
result := DllCall("winmm.dll\midiOutGetDevCapsA", UInt,A_Index-1, UInt,&MidiOutCaps, UInt,50, UInt)
List .= "|-Error-"
Continue
DllCall("RtlMoveMemory", Str,PortName, UInt,&MidiOutCaps+8, UInt,32) ; PortNameOffset 8, PortNameSize 32
;Msgbox Outports are %List%
