florian wrote:The "Bome Network" tool is a small tray/menu bar program for Windows and macOS which lets you connect to a BomeBox just the same as connecting two or more BomeBoxes. On the computer, it'll create a virtual MIDI port, so you can send and receive MIDI from any MIDI application to/from devices connected to the BomeBox. This works via Ethernet and WiFi.
The tool also allows one-click access to the web config of all connected BomeBoxes.
Soon, the tool will be freely available for all BomeBox owners.
Last, but not least, we're working on versions of Bome Network for iOS and Android.
Hope that makes sense!
OK since I'm running my Bome Box from an Iconnectivity 4x4 now, I can already pass midi back and forth from my PC as this device has ability to connect to 3 hosts simultaneously. I currently have it connected to both my Windows PC and BomeBox at the same time.
The ability to connect to the UI directly on my current network would be helpful. Right now, to move a bmtp file between devices, I do the following.
Connect my Chromebook to my home network and download the bmtp
Disconnect connect my Chromebook to my Bomebox (Wifi through different network) and upload the file. My Bomebox wifi is configured as DHCP server.
So moving projects between the devices is really kinda clunky.
I don't want to set up Bomebox as client on my existing network as I want to be able to run it stand alone if needed.
