BLE MIDI support for MT Pro
chris287
2017-01-17 11:00:05
Will there be BLE MIDI support for MT Pro?
2017-01-31 01:44:34
Yes, for Windows 10, we will add native BLE-MIDI support in a future version of MT Pro.
Recent macOS versions provide BLE-MIDI for all MIDI applications.
For older versions of Windows, you can use the WidiBud, it’s quite nice (and works on the BomeBox, too).
chris287
2017-01-31 03:30:36
It is good to hear your confirmation.    I visited your booth at NAMM  and two doors from you the booth of MIDI Association.   MIDI Assoication told me that BLE-MIDI is “embedded” in the “Inside Edition” of Windows and that software companies need to write a simple wrapper.      Before I went to NAMM, I tried a midi bridge program MIDIBerry.   Through  MIDIBerry I was able to connect the mi.1 Bluetooth midi transmitter to my Windows 10 PC and finally to a DAW.    In the end, it was because of  Bome MIDI Translator 2 that I was able to do Bluetooth midi at all because Bome MIDI Translator was the only only virtual midi device I could see in MIDIBerry!   So Bome MT Pro has a great start!     Anyway, MIDIBerry is not a usuable solution.   It is too unstable.
2017-01-31 13:28:15
Thanks for the additional info! Interesting feat in MIDI Berry… We have also thought of creating a small app for exposing BLE-MIDI devices to other ”old style” MIDI apps using the Bome virtual MIDI ports.
2017-01-31 13:30:45
PS: ”adding a simple wrapper” is not the full truth. You cannot put it directly into your program, otherwise it would be locked for Windows 10 only…
