LiveMap
2017-01-18 14:41:44
HI !!how to set a button to change the color on the akai apc20?
LiveMap
2017-01-18 14:41:44
ibanman555
2017-01-18 15:34:45
The APC 20 uses note on/off messages to turn LEDs on/off.
The velocity value will change the LED state of the button. Here are the values:
0=off, 1=green, 2=green blink, 3=red, 4=red
blink, 5=yellow, 6=yellow blink,
For example, 90 05 04 sent to the APC 20 will activate the 5th pad, blinking red.
2017-01-31 02:25:37
hey grey center, has ibanman resolved your issue? would you click the ”mark as resolved” button then? thanks!
greycenter
2017-02-01 01:45:14
good! and what to do, say if pressing the pad on the controller is assigned to a specific action program to hog the PC and at the same time want to have changed the color of the button ???
greycenter
2017-02-01 01:46:10
how to assign the following sequence of actions?
ibanman555
2017-02-01 02:18:40
2018-02-20 19:17:30
ibanman, do you have a MIDI mapping of all buttons on the APC20? I cannot find any documentation on this.
Bome Q&A moderator
