tech2
2017-02-11 18:28:03
Shiny (well not, but that's OK) new Bome Box on my desk. Instructions say I can log into it at it's IP address, and that works. Instructions also say I can use bomebox.box. I'd like to do that, since the IP address will vary, but it doesn't work using Safari on El Capitan, Sierra, or iPad.
2017-02-11 19:17:26
sorry for that, the bomebox.box address does not always work. For WiFi access, I guess it’s relatively simple to create a bookmark on 192.168.153.1 . And on a computer (Windows / macOS), just use the Bome Network tool: it has a menu entry to invoke the web config (no matter which IP address).
2017-02-11 23:39:13
I have mine set up with permanent IP address when connected to my computer (as slave) and for wireless I have it broadcast on it’s own network (totally different IP network) as a hotspot (separate SSID as well). That way I have two separate ways to access it and always know it’s IP address.
