Josh Wright
2017-02-13 02:32:14
Hi All,
So I know this has been covered on the old forum, but I get a fatal error from the web address when trying to go back and read posts again. SO .... Illl just ask it here :)
So I want have a button on my controller (Behringer X-Touch Mini) that sends repetitive messages while held down, then stop when released. This is often used with keystrokes, but I also want to use it to send repetitive MIDI messages. Any help would be very much appreciated!
2017-02-13 03:44:17
Try this
On note on, you set a repeating timer to continue sending note on messages. The timer actually sends the messages. You set another one shot timer by the note on timer to turn note off after a given period (less than the note on timer).
You use the global set the global variable gb to 1 when you push the key down. You set it to 0 when you release the key.
You kill the note on timer when you release the key so no more note on messages are sent (until you press another key).
arienrolle
2017-02-16 15:48:41
Great stuff! Is it possible to set a specific control (e.g. a knob or slider) to set varying beat resolutions?
2017-02-16 18:57:34
