Josh Wright
		2017-02-17 17:52:48
	Hi Everyone!!
Im hoping to get some help with getting a button to flash! Yeah I know rudimentary at best, but this is just a project that Im using to get to know the program. Anyway, Im trying to press one button, and have a second button flash its led 4 times. Im getting a flash... but its sporadic at best, and not consistent at all. Below is the code Im using... If someone could tell me where Im going wrong, I would be most appreciative. Thanks so much in advance!
[x] Translator 14.0: LIGHT ON INPUT
Options: swallow
Incoming: Note On on ch. 11 with note:8 (0x08) and velocity:127 (0x7F), on port X-Touch Alias
Outgoing: Timer 4 times "LIGHT ON TIMER": 500 ms (initial delay: 0 ms)
[x] Translator 14.1: LIGHT ON OUTPUT
Incoming: On timer "LIGHT ON TIMER"
Outgoing: Note On on ch. 11 with note:16 (0x10) and velocity:127 (0x7F), to port X-TOUCH MINI 1
[x] Translator 14.2: LIGHT OFF INPUT
Outgoing: Timer 4 times "LIGHT OFF TIMER": 250 ms (initial delay: 250 ms)
[x] Translator 14.3: LIGHT OFF OUTPUT
Incoming: On timer "LIGHT OFF TIMER"
Outgoing: Note Off on ch. 11 with note:16 (0x10) and velocity:0 (0x00), to port X-TOUCH MINI 1
		2017-02-17 18:24:32
	It looks like your timers may be getting out of sync. To keep things more steady I would  have a single translator for incoming action Light ON Timer and then use raw midi output to either turn light on or off toggling a variable.
So say global variable ga is your toggle
rules would be
ga=ga^1
The above would toggle the value of ga between 1 and 0 (assuming you initialized the value of ga t0 zero when you start the project
then the following rules
//Note on channel 11
if ga==1 then pp=0x9a
//Note off channel 11
if ga==1 then pp=0x8a
Your midi output would then be
pp 10 64
Typically I set a variable for the channel as well (say gb) at project start
//set channel to midi 11
gb=10
then another rule to or the value of the channel number with the status message
// note on
pp=gb|0x90
// note off
pp=gb|0x80
Edit: If you use this method and you want the light to flash on and off 4 times you would need to set the timer repetition to 8
		2017-02-18 02:50:57
	Here is a working example I set up for My LaunchControl. It goes a bit beyond my original description but I documented each variable I used. I also added an Init translator to reset global variables when keyboard escape is pressed.
