Geckocotechoco
2017-05-22 23:03:10
How would I get the Fader's pp to output through keystroke? So like my output would be "Somestring pp"
Geckocotechoco
2017-05-22 23:03:10
2017-05-23 03:21:56
I don’t think variables are allowed on outgoing keystroke actions. See the below thread
https://www.bomeloft.com/forums/viewtopic.php?f=3&t=12239&p=24704&hilit=keystroke+variable#p24704
With that said, whenever this capability is completed, here is some logic for setting the variables
ga= 100’s
gb=10’s
gc=1’s
Right now it just outputs raw midi “Sometext ” ga gb gc
as ascii characters
I suppose you could create translators to look at each digit separately and hard code the number output
I think you might be able to use variable to output to a serial port though.
I coudn’t find another solution other than the one shown in the link above posted.
Regards
Bome Q&A moderator
2017-05-23 05:15:15
I found this script that Florian originally started and made some mods.
Added 100’s
Added Pre-text
Set up different delay.
It should get you closer to what you are looking for but until we have global variables for keystrokes, it is not to pretty.
Bome Q&A moderator
