David Scrufari
2017-06-01 21:29:34
Hi, first off all congratulations for your outstanding software! I succefully connected 2 computers with network pro, its very easy to do and the latency is very low compared to others solutions. Thank you! However right now I miss the possibility to connect my ipad 2 midi controlers...Are you planning to release soon something to make this possible?
(Im really happy with bome translator pro too!)
Best regards,
David
2017-06-02 06:04:07
David,
I believe they are working on it but it is not yet available. They generally do not give timelines on development projects.
Regards
Bome Q&A moderator
2017-06-06 16:42:29
Hi David, Steve is correct. We work on it and have a first rough version running, but it will need some polishing before release. Stay tuned! And thanks for the kudos, much appreciated!
