Jannik
2017-06-06 17:05:03
Good evening everyone,
Has anyone an idea how I can "toggle" my LED Feedback for APCmini?
Per default its red. First press -> green blinking; second press -> default(red)
I know the MIDI Notes for the LEDs but can I get a hint how the syntax or the workaround is?
2017-06-06 18:33:23
Hi if you can send me the notes and values to turn various colors on and off (or the manual that show it), I should be able to help you put a translator example that you can use so that when you send note-on messages, it can toggle values. What device or software are you using to send midi messages to your APC mini?
Bome Q&A moderator
2017-06-06 18:39:15
I just found it,
note on with velocity 0 is off
note on with velocity 1 is green 2 is green blink
note on with velocity 3 is red 4 is red blink
note on with velocity 5 is yellow 6 is yellow blink
so what two states (colors) do you want to toggle?
2017-06-06 19:23:49
Assuming you want to toggle incoming note on messages (any velocity) between red and green it would look something like this
First you need to initialize a global variable to a note state so set a translator up for this at project start.
Input Event Project Start
Rules
// green is default state
ga=1
Output None
Then the translator to toggle the state
Input Note on Channel 0 Note 60 any velocity (or pick your note)
rules
if ga==1 then pp=3
if ga==3 then pp=1
ga=pp
Output
Note on Channel 0 note 60 velocity pp
