ydeeeee
2017-07-11 20:32:26
Hi I need help, can I convert midi (from usb Akai APC20) to OSC?
ydeeeee
2017-07-11 20:32:26
ydeeeee
2017-07-11 20:33:04
If its possbile than how please ? Thanks
2017-07-11 20:47:19
I know this is under development but have not heard of any anticipated release dates.
If you are using a Mac you might want to check into OSCulator if you are in a real hurry. You may also want to look into the below link:
https://github.com/fred-dev/OSC_MIDI_OSC
ydeeeee
2017-07-11 22:35:32
I am using Windows 10 and that is problem ? I try study something about your link. Thanks for your help. ?
