Create network connection between two ipad NOT WORKING
djthopa1
2017-08-22 02:52:49
Hi c0ngrats on your bomebox machine.
i have two ipads connected to the bomebox wifi. Ableton link works fine between the two ipads using the bomebox wifi.
Im trying to send the midi data from a novation launchcontrol connected to one ipad to control other apps on the other ipad to no avail.
is it possible? I have managed to achieve this with an ipad and the controller sending midi over wifi to a computer, but not between ipads.
is there any app that can do this? I have tried with a few apps like midi bridge and no luck.
network 1 /2 /3 etc domt seem to show up on any apps and midi ins or outs.
Hoping there  is solution, cheers
djthopa1
2017-08-22 03:15:54
Got it sorted with midibridge app. Its great not to be dependant on having a computer to create a hotspot that ios devices can sync to.
Would be great to have a network bomebox app for ios / tablets tough…
cheers
2017-08-22 03:35:55
Yes, Bomebox doesn’t currently support direct connection to IPAD. Bome Network is support on OSX and WIndows only, however I think they are working on an IOS solution as well. Right now Bridging between BomeNetwork on MAC or Window machine to RTP-MIDI (which IOS supports) I believe is the only solution.
Glad you worked it out!
Bome Q&A moderator
