fingerlight
2017-08-30 08:43:33
I'm currently using 4 virtual ports.
- MT --> Virtual Port 1 --> Ableton Live Instance 1
- Ableton Live Instance 1 --> Virtual Port 2 -->MT
and
- MT --> Virtual Port 3 --> Ableton Live Instance 2
- Ableton Live Instance 2 --> Virtual Port 4 -->MT
Would there be a disadvantage (or advandtage) if I did this instead?
- Ableton Live Instance 1 --> Virtual Port 1 -->MT
and
- MT --> Virtual Port 2 --> Ableton Live Instance 2
- Ableton Live Instance 2 --> Virtual Port 2 -->MT
....or... does it even matter?
Gabriel
2017-08-30 18:58:53
Hi Gabriel. No disadvantage that I’m aware of.
2017-08-30 19:04:19
The only thing I don’t think works is looping back on MT1 Out back to MT1 in. For that I would use something like MIDILoop or MID Yoke (if on Windows). I think I ran into this as an issue before if you are trying to process the additional input coming back from MT1.
I think Mac has a native way to create and use virtual MIDI ports.
2017-09-01 13:56:06
Hi, just a quick addition: you can use the Bome virtual MIDI ports generally in both directions, also for a loopback — on Windows and also on Mac.
Just make sure to not create an infinite loop — e.g. if your DAW is set to MIDI Thru/Echo (MT Virtual 1 IN to MT Virtual 2), then connecting Virtual 1 IN to Virtual 1 OUT in MT Pro will create an infinite loop, which can slow down your system considerably…
