Gabriel,
Thanks so much for testing this! It looks like I will need to do a few tweaks before releasing this functionality.
Gabriel->
Translators 1/9 and 1/10 seem to be relevant to an earlier version of MIDIBuddy. They output X Timer and Y Timer, which are not used as input to the translators that follow.
Translators 1/11 and 1/12 output X Timer1 and Y Timer1 which is correct.<-Gabriel
Steve-> 1/9 and 1/10 can be disabled, however I keep sending these outputs to make it backward compatable with previous version. <-Steve
Gabriel->
Translators 1/13 and 1/14 output X Timer2 and Y Timer3 which is correct.
So I get the outputs I need, though I would change Translators 22 and 23 so they output B0 02 and B0 03 rather than B0 03 and B0 04.<-Gabriel
Steve -> You can modify the MT Pro file as needed. I just set these output up for testing <-Steve
Gabriel->
And yet, MIDIBuddy seems to be outputting the following strings simultaneously: F0 7D 42 4F 4D 45 7F 02 00 pp qq rr ss F7 (which would be seen by Translators 1/9 and 1/10) as well as F0 7D 42 4F 4D 45 7F 02 08 01 pp qq rr ss F7 (which is seen by Translator 1/12 and 13 as it should be).<-Gabriel
Steve -> I did not take away MIDIBuddy functionality. You can use either input but probably not both. It depends on what you want to do.<-Steve
Steve-> 1/9 and 1/10 should probably be labeled as absolute pointer mouse position as opposed to mouse movement. If the mouse is frozen then the cursor will not move so in essense. 1/9 and 1/0 report the actual absolute cursor position on the screen while 1/12 and 1/13 record relative mouse movements commands sent to MT Pro (even if the cursor does not move)<-Steve
Gabriel->
Translator 1/15 does see output from MIDIBuddy in response to Scroll Wheel movement of mouse 1.
But its output is X Timer1. This should probably be X Timer3 so that it is used as input for Translator 1/24, otherwise it would conflict with horizontal movement of mouse 1.
I’m not sure what Translator 1/16 is supposed to do, since there’s only one Scroll Wheel per mouse. Maybe it’s meant to be used for Scroll Wheel press? Same for Translator 1/18.<-Gabriel
Steve-> Yes, again I only used this for testing not for setting up a user project file. In my test I only enabled one at a time so global variables did not not matter.
On some mice, you can side click on the mouse wheel for horizontal mouse movement. This is what 1/16 and 1/18 are for.<-Steve
Gabriel->
Translator 1/24 and 1/25 should probably be named X Timer3 and Y Timer3 – though, again, I don’t know what Translator 1/25 would be used for.<-Gabriel
Steve-> Again the MT Pro file is just for testing. There are so many combinations of output available, I didn’t intend to use it as a user template but maybe I should create one with generic outputs. If I did, the likelihood that a user would change them is high which of course would effect the global variables I chose. I will probably provide a more advanced MT-Pro template in the future. Right now, my focus was on getting features added to MIDIBuddy.<-Steve
Gabriel->
So, what I’m missing is X Timer4, which would be used for Mouse 2 Scroll Wheel.
Mouse 1 and 2 Left Button presses and releases are handled correctly by Translators 2/2 and 2/3<-Gabriel
Steve-> Yes simply duplicate and modify any translators that you want, if you want additional timers.<-Steve
Gabriel->
Mouse 1 Middle Button press and release is handled correctly by Translator 2/4, though on my mouse it’s actually Scroll Wheel press and release.<-Gabriel
Steve->Yes the middle button on my mouse is also scroll wheel press. It also has scroll up, down, left and right functions. My guess is your’s is too if you give it a try.<-Steve
Gabriel->
I’m not sure what 2/8 through 2/16 are meant to do.<-Gabriel
Steve-> Another user asked me to handle this unique situation. He presses a key on his controller for mouse down only so he can drag a mouse pointer. However if he touches the real mouse, he didn’t want the pointer to continue to drag so this monitors for that and releases the mouse down button if he happens to touch his mouse.<-Steve
Gabriel->
I don’t understand why Translator 2/17 responds to Middle Button press and release (Again, this is Scroll Wheel press and release on my mouse. I’m holding the mouse absolutely steady, so it’s not that there is some x or y axis movement of the mouse. For some reason, MIDIBuddy is sending F0 7D 42 4F 4D 45 7F 02 08 01 00 00 01 00 F7 for Scroll Wheel press and for release too.
<-Gabriel
Steve-> I’ll check into this. This is for relative mouse movement but if the mouse is not trying to move it shouldn’t send. I think I will suppress any mouse move messages where the lsb of both axis is 0.
It should send this for middle press and release. (without the header and trailing F7. This is all for unique mouse reporting
Middle Mouse – 04 mm 02 03 01 – Down , 04 mm 02 03 00 – Up
For scroll it should send this:
Scroll wheel – 04 mm 02 02 01 – Up, 04 mm 02 02 02 – Down, 04 mm 02 02 03 – Left, 04 mm 02 02 04 – Right
In addition it will send the original (non unique mouse scroll commands)
Middle Mouse – 02 03 01 – Down , 02 03 00 – Up
Scroll wheel – 02 02 01 – Up, 02 02 02 – Down, 02 02 03 – Left, 02 02 04 – Right
Again you only use the messages you want but I don’t recommend using all messages due to possible conflicts. This is by design for backward compatibility <-Steve
Gabriel->
In response to Scroll Wheel Movement, you are sending the timers with a repeat count of 20. I think, since we’re using Relative (BinOffset) — I’m actually using Relative (lin BinOffset – not sure if that makes a difference — it might be possible to send, for example B0 00 48 for increment and B0 oo 38 for decrement (or something greater than 48 and smaller than 38) in order to avoid sending the output multiple times. If we find the correct values to send, I think wemight be able to avoid using timers entirely, and just send the outputs directly. I haven’t tried this yet in this project file, but have done so successfully in my actual project file. <-Gabriel
Steve-> Yep, each user will have their own application that has it’s own needs, which is the value of MT Pro. You can tweak the incoming messages to practically any outgoing message you want. <-Steve
Gabriel->
So…. there you have it. Hopefully this all makes sense. Gabriel
Thanks for the test and detailed report!
