Ok, I have come back and re-read this a few times now. It is very helpful, hut there are still some things I don’t fully understand (yet).
For example:
Determining midi channel by “masking lower four bits (0x0f)” – what is going on here? I mean, I understand the result, but I don’t understand where the 0x0f comes from, and what it means. Is the “x” in this string a multiplication? Clearly there is no “x” in the hexadecimal system. I also don’t *really* understand what a bit is, in relation to the message we are dealing with, and therefore what the “lower four bits” really means. Also, I don’t exactly understand how or why “tt=oo&15” achieves this masking and lets tt=incoming channel number.
SJC> OK if you look at a binary value of a 8 bit MIDI Bite it looks like this
1111 1111
I separated the values by “nibble” which is 4 bits. The right most bit of each
nibble represents 1, the next one 2, the next one 4 and the left most bit is 8
So to represent different numbers
000=1
0001=1
0010=2
0011=3
0100=4
0101=5
0110=6
0111=7
1000=8
1001=9
1010= 10 decimal (A Hex which is represented as 0xa)
1011= 11 decimal ( 0xb)
1100=12 decimal (0xc)
1101=13 decimal (0xd)
1110-14 decimal (0xe)
1111-15 decimal (0x0e)
so 1111 1111 represents 0xff (first nibble 0xf0, second nibble 0x0f)
the MIDI command for note on is 0x9n where n is the channel number starting with zero. So 0x90 is note on MIDI channel 1. 0x91 would be note on MIDI channel 2
and so on.
What we do here is OR the bits together. The operator for or is “|”
1 OR 1 = 1
1 OR 0 = 1
0 OR 1 = 1
0 OR 0 = 0
So if we take the first nibble 0xB0 and OR with the channel number we get the
full note on and channel message
1011 0000 (0xb0)
OR
0000 0000 (0x0)
1011 0000 (0xb0)
If we OR it with channel 1 we get
1011 0000 (0xb0)
OR
0000 0001 (0x1)
1011 0000 (0xb1)
So essentially we are building the note on message with the channel number in
the rules
<SJC
Moving on:
“Get the command (upper value)”… We are getting the message type here (i.e. Bx for program change, 9x for note-on [where x is the channel in hexadecimal])? Is that correct?
SJC > Yes
<SJC
Next:
“// 0xF0 = 240 decimai” I think this is a typo-error for decimal, but I’m not sure why “uu=oo&0xF0” achieves the result we want, which I guess is to “let uu equal message type” [unless I was wrong about what was meant by “Get the command” earlier]. (Is this using more masking, perhaps?)
SJC> Not a typo. For an 8 bit number the lowest bit on the higher nibble is 16
So 0xf0 converted to decimal is 240
1 times 16
plus
1 times 32
plus
1 times 64
plus
1 times 128
128+64+32+16 =240
<SJC
(Aside:
I managed to negotiate the line “of uu!=0xb0 then exit rules, skip outgoing action” but only after pulling up a pdf of the manual and using the search function to find instances of “!” – my lack of experience with scripting, programming, etc, meant that I did not realise “!=” was a simple “does-not-equal”. I think it was on page 60-something of the manual. I have included this so you have some idea of the ignorance with which I am approaching this. I have, on a few occasions, read through the manual, and the forum, and seen a lot of your videos, but it is exceptionally difficult to take it all in, and I always find I don’t understand or remember the information I need when I need to use it!)
SJC> Thats OK, we all started here at one time or another. Part of the learning experience.
Further:
In the “if uu!=0xb0 then…” line, I don’t understand this now familiar type of string, here represented by 0xb0. I mean, I assume it just means “B (change command)” but I am hazarding guesses at a lot of this.
SJC> If uu is note equal to hex b0 (decimal 176) then ..
0xb0 is the command (upper nibble) for a control (CC) message on channel 1
For instance if you want to change controller number 1 on MIDI channel 2 it would be
0xb1 0xnn 0xvv
where nn is the controller number and vv is the value
<SJC
Final section:
How does ORing the command and the channel together work? My internal logic doesn’t like “let z=a or b” leading to “z=ab”, or “z=a_then_b” although I’m sure this is my stupidity. I am assuming from “// vv is now 0xB4” that vv is now what I would have thought of as B4 (cc change on channel 5).
SJC>
Hopefully this is explained above already)
OxB4 is Control change on MIDI channel 5)
<SJC
If you have time:
– I noticed yoy did not include an outgoing message, would this set of rules be used in conjunction with the other rule/translators to achieve the “velocity-to-cc41-and-sent-BEFORE-note-on” result, or did you envisage a single self-contained rule to do the whole process?
Is one way obviously better than the other?
SJC> Including all rules in one translator vs multiple translator is usually a matter
of choice. For me, if I already have a translator that handles a given function, I try and leverage it rather than duplicate it in multiple translators. That way, if I later need to change it, I can change it in one place rather than many).
<SJC
-Would replacing the last action in the rule with “vv=uu|tt” mean that vv became a control change message (B) on whatever the input channel was, or am I way off the mark?
SJC> You are right on
<SJC
And just for clarification:
Some of the four character strings which begin 0x (such as “0xF0” and “0x0f”), have got lower/upper case letters (aside from the lower-case “x”). Is this intentional? Are they case-sensitive strings? Do f and F mean different things there?
SJC> Case is insensitve in MT Pro 0xf0 is the same as 0XF0.
<SJC
Thanks so much for the help you’ve already provided me with this.
SJC> Your quite welcome!
<SJC
