Some more questions…
if you connect the Mackie to your Windows 7 computer, do you see a MIDI interface appearing for it?
No, i see TT24 usb and com3 but no midiTT24
If no, does it appear as a COM port? com3
If yes, please make sure to use MT Pro beta 1.8.3 (not 1.8.2). yes i have lauch this 1.8.3
do you see continuous FF input in the Log Window when moving any of the faders?
no. I see Midi FF but sometimes nothing happens. I managed to get other messages by com 3 but I had to cheat.
I noticed that when I run TT24 software for a second I get com3 data (see screenshot).
if I only plug the umone midi jacks and I debranche usb tt24 I get only the faders and mutes but no other signal.
in conclusion I think more and more that the other parameters are not implemented on the midi output the documentation
explains that the purpose of the MIDI socket is to connect a second TT24 console that will reproduce identical
fader levels and mute snapshots but no other parameters.
If yes, it’s likely that the serial port rate is wrong. Try other values.
I tested the other speeds but I have no more data.
I made a screenshot of the parameters of the com port and USB port TT24 we are 9600 baud in 8 bit
without parity stop bit 1. the same parameters in MTPRO
we are 9600 baud in 8 bit without parity stop bit 1
when I run the software TT24 control I receive on the com3 port data Midi FF BF FF ...
it is progress. but it only lasts a second. after access to the port is denied.
TT24 control refuses data sharing.
Sorry if Steve has already asked some of that…
no problem thnak’s for your help
