Bome Network Auto Connect
Jens1
2018-05-31 18:36:41
does the Pro version of Bome Network support auto-connecting to other computers (Macs) on the network when they become available?
Thanks & best regards Jens
2018-06-01 06:17:29
Hi, Jens,
I think so but not 100% sure. I’m only running Bome Network between computer and Bomebox so I’m checking on this. Hopefully I will find out tomorrow. Sorry for the delay!
I know when I pair my BomeBox with my computer, I generally do not have to pair it again unless I’ve changed something significant in its configuration.
Bome Q&A Moderator
and
Independent Bome Programming Consultant/Specialist
fspshowband
2018-06-01 08:07:58
Thanks for checking!
Florian Bome
2018-06-01 17:33:52
Hi, yes, once two computers are “paired”, they will immediately re-establish that connection whenever both computers are available. You can pair as many computers as you like.
I hope that answers your question.
Best,
2018-06-01 18:21:08
Thanks, for chiming in, Florian!
fspshowband
2018-06-02 00:36:55
Great, thanks for your answer! I think this feature should be listed on the product page because that‘s a real advantage over Apple‘s implementation.
Best regards, Jens
