magicizaproblem
2018-07-15 15:47:21
Is there a shortcut to check and uncheck presets and translators so i dont have to use the mouse?
magicizaproblem
2018-07-15 15:47:21
2018-07-15 17:36:30
I’m not sure on Mac but on Windows, if you have your cursor in the preset window, you can use up and down arrows to select a given preset and then space bar to toggle enable/disable for the preset you currently have selected.
magicizaproblem
2018-07-15 22:08:58
Thanks Steve that worked!
2018-07-15 22:11:45
You’re welcome, Preston!
