darvas
2018-07-30 17:37:25
I am mapping an APC mini midi controller with has designated midi notes defaulted to Midi channel 1. I would like to map a separate key which upon pushing it , it would change all the buttons to send to midi channel 2 and mapping an other button would do channel 3 etc...
What is the easiest way/ script to do this?
2018-07-30 17:53:25
The easiest way would be to create a global variable (ie ga) which depicts the MIDI channel you want to transmit. The default value for any global variable upon project open is 0 (which would be MIDI channel 1).
Then have a translator that changes this variable when pressing a given button (or computer keystroke).
Then you would need translators set up to translate incoming note and CC messages from incoming of channel 1 to outgoing of channel ga. Here is an example that would handle both note and CC messages (any 3 byte MIDI sequence).
Translator : Translate Note and CC from Channel 1 to channel gc
Incoming: Raw MIDI Message pp qq rr
// Change outgoing channel
// pp is a combination of MIDI message and channel IE 90 is Note on MIDI channel 1
// We need to capture the first digit 9=note on 8=note off b=CC message and the OR it with the target outgoing MIDI channel
// This will clear the existing incoming MIDI channel. Really not necessary if it is MIDI
// channel 1 since all these bits are already cleared. However, it would be necessary for any
// other incoming channel so I suggest you leave it in. There will be other rules needed if you
// want to ignore other incoming MIDI channels. This translator will translate ALL incoming
// channels to the target outgoing channel “ga”
tt=pp&0xf0
// Now lets OR the MIDI Type message with the target outgoing MIDI channel of ga
pp=tt|ga
// pp should not have the MIDI type and target outgoing channel so it is ready to send in the
// outgoing raw MIDI message
// End of Rules
Outgoing: Raw MIDI message pp qq rr
Options: Swallow
darvas
2018-07-30 18:03:46
Hi Steve , thanks for your quick solution. sorry for my ignorance but I am very new to this software. Looking at your solution above , I am not sure how to go about it, where do I enter all this info?
Thank you.
darvas
2018-07-30 18:13:40
Thank you.
2018-07-30 18:50:17
