Changing global MIDI channel with designated buttons from the same MIDI controller( AKAI Midimix)
darvas
2018-07-31 16:39:29
Hi All I am using 1 controller (AKAI midimix )and what I need to do is to designate 8 hard buttons on it( in this case the mute buttons) ,so when I push lets say the first one all my sliders are sending out on channel 1. when I push the second button then all the midi info goes out on channel 2 and so on. can please let me know how to do that. In this case , I need all my sliders and pots but I am planning to use the mute buttons 1 to 8 to change the MIDI channels. All the Midi info is the same for all the outputs ,ALL I need to change is the midi channels ,so I can program my software on different computers to its according MIDI channels.Thanks
Please let me know how to do this. much appreciated. George
2018-07-31 17:44:20
Hi George,
I believe this is duplicate post so please delete it. You are the only one that can delete and existing thread that you started.
2018-08-02 15:27:06
Not sure because I’ve never deleted any however I’m told that if you create the post, only you can delete it. I wouldn’t worry about it.
