USB-MIDI connection ﹰBomebox/BCF2000
wereMole88
2018-08-03 06:23:41
Hello,
I've connected my MIDI controller (BCF2000) to my Bomebox USB 2.0  host port. But it sends no MIDI to the Bomebox (no flashing LED). I've checked the following:
- Bomebox does receive on DIN port, network port and wireless with the Network tool.
-BCF instantly works when connecting to PC.
- It is in the right configuration (it does successfully send over DIN)
- it says in the manual it's class compliant.
Am I trying something that isn't supposed to work? I was under the impression that it should be possible to have the Bomebox as an USB host for MIDI transfer for these kind of devices.
2018-08-03 06:41:16
Have you set up your MIDI routes?
Please review the below tutorial. You will need to ensure there is a route set up from your USB port to either another connected device or to the network MIDI.
https://youtu.be/aTFTgM9Dqic
When you look at devices on the web page, does it show the BCF2000? The flashing LED is only for the DIN port.
wereMole88
2018-08-03 06:52:46
Well that explains. I do see an USB BCF2000 device in the Bomebox routing page. I just thought it was not doing anything because of the LED.
I will set this up properly in the evening and see that i can send some MIDI to my PC to verify whether it works.
TYVM
wereMole88
2018-08-03 18:15:18
Allright I got it working in 5 minutes after opening & connecting the right ports. Sends and receives MIDI flawlessly.
Thanks again!
2018-08-03 18:36:02
Super, glad to help!
