Polyphonics
2018-10-24 23:19:01
I've built myself a custom e-drum kit and Bome plays an important part in how I use it with software. I have two modules, which means I have two HiHat controller inputs. Since you only need one hihat on a kit I was wondering what I could do with this spare input, then I came up with the idea of a shaker pedal.
The goal is to depress and release the hihat pedal so that it feels like a shaker; similar to when on acoustic kits, drummers mount a tambourine above the hihat cymbal. As a starting point I pick a median-ish number on the CC, say 62 which triggers a ''shake'' sample, then maybe use 127 to trigger a ''tap'' sample (using a Bome translator of course).
But I wanted to take this idea further and see if I can make the shaker more dynamic, for me when I use a real tambourine, the faster the shake the louder it is (probably not the case but thats the ''feel'' I get anyway).
So, could I use Bome to measure how fast I am moving the pedal and translate that to velocity? I know that Bome can delay a translation by a set number of milliseconds, so does this mean the software can measure time between CC values? I'm no programmer but the rule I'm picturing in my head would be something like note velocity = time between CCX x CCX.
