Martin Knott
2018-10-25 22:45:48
Hi, I'm trying to pause a tick for Tap Tempo derived from Midi Clock every 4 beats, but I do something wrong in scripting:
// timing
if g0<1 then Goto "1st Trigger"
if g0<23 then Goto "Ignore"
if g0>23 then Goto "Trigger"
// 1st
Label "1st Trigger"
g0=g0+1
h0=h0+1
// ignore
Label "Ignore"
g0=g0+1
exit rules, skip Outgoing Action
// Trigger
Label "Trigger"
if h0>7 then Goto "reset"
if h0>4 then Goto "noclick"
if h0<5 then Goto "click"
// Trigger VARI
Label "noclick"
g0=1
h0=h0+1
// clicker
Label "click"
g0=1
h0=h0+1
// reset
Label "reset"
h0=0
What is there going wrong, I can't find the mistake?
Martin Knott
2018-10-25 23:03:22
// timing
if g07 then Goto “reset”
if h0>4 then Goto “no”
if h0
2018-10-26 06:50:51
Maybe I missed it but I don’t see where you ever set g0 back to 0. So you will never get more than one “1st Trigger”.
Martin Knott
2018-10-26 09:54:25
In the version above were different bugs, but g0 ist set to 1 under the label \"click\", because I needed the first impuls for a click too.
I’ll send the version which works for me now, but I’d like to solve it in the other version too…
This is, what i wanted to do:
g0=g0+1
if g0==1 then Goto “A”
if g0==24 then Goto “A”
if g0==48 then Goto “A”
if g0==72 then Goto “A”
if g0==192 then Goto “B”
Label “A”
Label “B”
g0=0
exit rules, skip
2018-10-26 14:33:44
What do you want to happen if g0=23?
2018-10-26 14:54:14
OK, try this file. The translator “Debug Me” is yours.
I fixed two lines. Both have comments above the fixed line with what it was and *** in the line.
// was >23 *****
if g0>=23 then Goto “Trigger”
// clicker
Label “click”
g0=1
h0=h0+1
// was skip outgoing action ***
I used a timer to simulate the MIDI clock. A simple note on message with velocity set to h0 to see the ticks.
