2 midi controllers at the same time possible?
baritonsaxofon
2018-11-19 16:12:52
Hi Steve, is it possible to work with 2 Controllers at the same time? (e.g. Allen & Heath Xone K2 and the Novation launchpad MK2)?
Thanks for answer
Peter
2018-11-19 16:35:12
Hi Peter,
Entirely possible, however in many cases you will dependent on the design of the application you are using. In many cases, we can use Bome MIDI Translator pro to extend the application functionality my either making it look like a different type of controller or modify the behaviors of you controllers more to what the application expects. Many applications natively support multiple MIDI controller types attached natively.
What is the software you would be using with your Xone K2 and LP MK2?
