Preset & Translators; Grouping, Minimizing, and project organization.
cymaticstudiosllc
2018-12-08 06:45:13
First, I just want to say, this program changed my life. It drastically improved my workflow, which naturally means more cash flow. You've created a way to marry all of a studio's hardware and software, and laid the groundwork for a level of communication between them that bares infinite creative potential. Love it.
Alright now to the questions. Are there any plans in the future for grouping and minimizing Presets and Translators with the ability to activate and deactivate entire groupings? some of these projects files get very large and difficult to manage, and currently there are very little organization/housekeeping tools available. What would make these groupings even more powerful, would be if you gave translators the ability to trigger other translators, in a similar fashion to the "Preset Change"option already in the "Incoming & Outgoing" sections. Call it a "Translator Change" if you will. On top of that,  you could give that translator the power to also trigger/toggle the on/off status of the suggested "translator-groups, presets, and preset-groups".
Any way, just a suggestion/inquiry. these would help make the program easier to navigate and stay organize, while simultaneously make each translator much more powerful. Thank you guys!
2018-12-08 14:37:39
Hi, great suggestions. I know Bome is working on some of this but I’m not privy to the details and especially time lines.
As far as translators triggering other translators, this is possible using one shot timers. I do this all the time. You have translator 1 trigger a timer by name (say “timer group 1”).  Any translator with incoming action of “timer group 1” will trigger.  Kinda sounds like your concept of “translator group”.
Typically I do this with a timer I call “Init” as follows:
Translator – Incoming Action – On project open trigger “Init”
Translator – Incoming Action – On pressing computer ESC key “Init”
Translator – Incoming Action “Init” –  Set global variables.
Translator – Incoming Action “Init” – Outgoing Action Timer “Refresh “LED”
Translator – Incoming Action “Refresh LED” ga times
// Rules to iterate through the various LED note numbers and values.
… ie ga=ga-1
Outgoing Action Note on note ga value gb (just as and example)
You can have as many translators with the same incoming action as you want. You can even group them under different presets so that you can enable and disable various ones by the enable/disable preset actions as well.
Most of the issues I have are not with the flexibility of MT Pro with my thinking through how I want to organize the project for maximum flexibility with minimal maintenance.
For instance, I rarely direct incoming and outgoing MIDI actions to a given port. I usually just set default ports at the project level, Organize my presets by their port names (aliases) and the override the default ports within the presets. Occasionally I have a translator within a preset to override the preset ports.  I do heavy use of aliases since I have many MIDI controllers and usually not the same as users that ask questions on this board. This way I can just use the alias name for their controller and with reassigning the alias all of a sudden use a total separate controller (or controller emulator using MT Pro).
I also have a few quick reference documents that I keep to remind me how to handle more complex things like boolean logic and bit mapping (for LED control). Most of this I found by search on the old forum.
Another technique for controlling the enabling/disabling of translators is to use a global variable and then put a rule in the translators to look at that variable. An example of this is using the translator for a “shift” function or shift state. For instance you use ga for example to turn on the shift function and then check it with rules in the translators
// Execute action only if non-zero
if ga!=0 then exit rules, skip outgoing action.
I hope this helps!
cymaticstudiosllc
2018-12-09 00:40:55
the support for this product is some of the best I’ve seen, so thank you for that!. And hank you for the tips. I do currently use a lot of switcher profiles. in fact 90% of all my presets are switchers, Ishould definitely seut a INIT, and reset preset though, that may help me solve a lot of problems.
Cheers, and thanks for the awesome support Steve!
Ben Governale
Cymatic Studios, LLC
2018-12-09 04:15:25
Thanks for the good words, Ben. My pleasure!
pedro.estrela
2020-09-30 23:15:45
good comments above.
Annexed a very simple way to active all presets from 0..10 in a single go, inspired by this post.
My case is simpler as I do not need grouping.
On th wakeup timer I set \"ga=10\", then schedule the worker timer 10x times, and in the worker I subtract \"ga=ga-1\" and activate preset \"ga\"
this is another good post as well:
https://www.bomeloft.com/support/kb/preset-translators-grouping-minimizing-and-project-organization
Process-and-port-management-pedro2.bmtp
