SteveC
2019-02-15 15:24:56
A user just indicated that the trial version of MT Pro does not include the manual. While we work on fixing this, I will include a copy here.
SteveC
2019-02-15 15:24:56
2019-02-15 15:32:17
Here is a link to the user manual until we can fix the problem with the Evaluation Copy of MT Pro where the manual was not included.
Florian Bome
2019-02-18 11:47:48
MIDI Translator Pro normally installs the User’s Manual correctly. The only exception is when the user chose “custom install mode” on Windows, and then deselected “Help Files”.
So if you encounter this problem, please reinstall (over-install) MT Pro, chose custom mode, then make sure all checkboxes are ticked:
petergtinsley
2019-02-18 12:00:01
Florian Bome
2019-02-18 20:49:23
Interesting. Seems that on your computer, MT Pro somehow cannot find the PDF viewer. Which program do you use for PDFs? Which Windows version are you using?
petergtinsley
2019-02-25 07:41:01
Florian Bome
2019-02-25 22:07:03
Hi Peter, thanks for further testing and reporting. The difference is that when opening a file from Windows File Explorer, it adds further checks if a viewer is installed.
Integrating a PDF viewer would be a possibility, but not so easy as it seems. At this point, we just require a PDF viewer application being installed on the computer. Maybe MT Pro can be smart about it: if the normal way to show it does not work, launch a web browser to show the PDF.
Helmut Schneider
2020-04-01 13:06:58
2020-04-01 20:21:30
