midiot
2019-05-14 23:02:39
The X axis is correct, but Y is way off.
I'm using a Mac Book Pro 15" with trackpad (not mouse).
I can successfully input the coordinates manually, but that's no fun....
midiot
2019-05-14 23:02:39
2019-05-15 01:51:48
I’ll check into it to see if I have the same issue.
2019-05-15 02:17:38
Yes on mine for mouse position using capture it always seems to want to set Y position to the same as X position. I will pass this message on for you to the developers.
Florian Bome
2019-05-15 11:56:06
This is a confirmed bug in v1.8.3!
Will be fixed in the next version of MIDI Translator Pro.
Thanks for reporting.
