SteveC
2019-07-03 18:08:09
User requested via email to create a MIDI to Keystroke template for all available keys.
Will attach a template here that all users can use as needed.
SteveC
2019-07-03 18:08:09
2019-07-03 18:15:09
The attached template is an example. It takes MIDI note-on messages on MIDI channel 1 and outputs keystrokes as shown here.
It should be a good starting point for anyone that wants this functionality. Note, it currently doesn’t:
To optimize your time if you need to create something similar manually, here are the steps.
1) create a full translator MIDI -> Keystroke Key (not Text)
2) duplicate this translator 128 times with Ctrl-D
3) Now edit the first outgoing keystroke
4) TAB to get out of the keystroke editor
5) Ctrl+N to go to the next translator
6) Shift+TAB to get into the keystroke editor
7) edit the keystroke
8) goto 4)
The project file and steps were created courtesy of Florian Bomers so I posted here for all users to enjoy!
