mwesse
2019-07-13 12:06:15
With multiple midi input ports, it use to be quite easy to ascertain them in either max, midiox/vbscript etc which made it convenient for remapping controllers etc and is an important definition. Am I missing something...it looks like that is not available in MTP?
Cheers
2019-07-13 15:27:45
Hi Mark,
I’m not sure I understand. You should be able to see all available MIDI ports available when opening MT Pro, you may not be able to open some of them, however if they are being used by another application.
They can be seen if you click on the project level in the preset browser and then look over to the right to see all available ports.
See screenshot.
