natanael.cognac
2019-08-29 17:06:51
I've got a drum machine, master clock, in midi DIN in, going out midi DIN out of the bomebox.
If I create routes (Midi DIN IN -> Midi DIN OUT), the clock works fine.
But if I do it in a script (see btmp file attached, the preset is called : digitakt In->Out), the synchronisation is out of control :
- the slave sequencer works (play & stop)
- but the tempo is very irregular and roughly 2 times the normal tempo (master : 90bpm, slave between 160 & 200bpm)
Any idea about what is missing in this script, or what I do wrong ?
Thanks a lot !
PS: the script is not from me, I don't remember where I found it (forum? video ?), but I'm pretty sure it's Steve's one.
2019-08-29 19:10:04
Try the attached and see if it works better. What I did:
- Reversed the order of bytes translators. Instead of 3 bytes then 2 bytes then 1 byte, I made it 1 byte, 2 bytes, then 3 bytes
- Put Stop processing after each translator. For a computer the MIDI driver usually knows how many bytes are in the message, but this is not always true for MIDI DIN connections.
To make it even more robust your might want to use incoming F8, FA, and FC as three separate translators instead of just oo as a single tranlaor. For instance, if the timing of the incoming message of the MIDI port is a bit slow, a 3 byte message actually may be interpreted as 3, 1 byte messages, so best to make the pattern more complete to avoid this.
Again this is usually not a problem with a USB MIDI driver that does some byte length interpretation. It would only be an issue with MIDI DIN which has no concept of completeness of MIDI messages.
I think I will discuss with Florian to see if he has any plans to interpret raw MIDI messages on DIN ports to validate the required length of them. It may be more complex to do this however, for instance if you are looking for a sequence of multiple MIDI messages as raw byte like 3 separate note messages like 90 02 7F 90 03 7F 90 04 7F. This is really 3 3 byte messages but having an input pattern like this can make MT Pro (and BomeBox) more powerful by interpreting a longer sequence of MIDI events.
natanael.cognac
2019-08-31 11:16:52
Thanks very much, that works !
And in addition, I’m going into midi in Din on the bomebox, but now I’m going out with midi USB.
Do you know what is best concerning stability ? Because I could do everything with midi over usb. I’ve read the cons :
– slightly slower (but nothing really, doesn’t make a difference for me)
– less ground isolated
But what are the pros ? Will my setup be more stable if I use only midi over usb ?
Thanks !
2019-08-31 15:59:15
I think actually MIDI over USB would be faster for long MIDI messages like System Exclusive but maybe a bit slower for 1-3 byte messages because of the USB overhead. I might be wrong though as processing USB messages is pretty darn fast.
MIDI over USB could be better for 2 way communications because you have 1 cable instead of 2. Also since BomeBox only has 1 set of DIN connectors but with a USB hub, you can get multiple connections over USB into your BomeBox.
Typically I only use the DIN connection for concerns about ground isolation or on older legacy gear that only has DIN.
brettyriley
2020-04-10 00:47:13
If I want to forward the start stop and clock messages from my sequencer to BMT then from there I can use a virtual port to provide clock to the gear that needs it.
What messages need to be forwarded to constitute a full clock signal? I tried with start stop, timing clock and continue song messages but ableton still doesn't recognise them.
2020-04-10 01:04:29
SJC> For sending full MTC (MIDI Timing clock) messages to your gear, it would be best to
- Create static routes between your source devices and the devices that need the time click
- Add translators that block any other messages that would otherwise pass through. Usually these are any 2 or 3 byte MIDI messages so if you put rules for:
Input : Raw MIDI oo pp
Output: None
Input: Raw MIDI oo pp qq
Output: None
And set swallow on for both translators, you should be covered for most other MIDI messages.
Or you could be more specific and block:
Input: Note-on any channel any note
Output: None
Input: Note-off any channel any note
Output: None
Program Change any channel any value
Output None
CC any channel any CC any value
Output: None
brettyriley
2020-04-10 01:30:35
How does this apply for Midi Clock instead of MTC? Is it the same principle of filtering any additional messages from that input?
Squarp-->BMT 2 --> any devices needing start stop and Midi clock. With notes and ccs filtered. T
If i understand correctly this will only forward timing information to BMT 2 out?
And Ableton will get it's 'sync' signal from This channel?
2020-04-10 04:13:41
How does this apply for Midi Clock instead of MTC? Is it the same principle of filtering any additional messages from that input? Squarp-->BMT 2 --> any devices needing start stop and Midi clock. With notes and ccs filtered. T If i understand correctly this will only forward timing information to BMT 2 out? And Ableton will get it's 'sync' signal from This channel?
SJC> You can do it either way. Clock messages themselves are a single byte and defined as a proper incoming action. They have no channel. Depending on the implementation of the DAW, start,stop may be MMC messages or may be implemented as simple note messages.
In general if you use the static router, you must suppress anything you do not want to go through the default routes with translators. If you don't use the static router, then you need to create translators for anything to go through. So the choice is usually what implementation would require the creation of the least amount of translators.
