cascaded presets / loopback devices
pedro.estrela
2019-09-29 19:21:56
Hi Can you please help me create cascaded presets / loopback devices? Basically, how can I route the output of a preset into another preset?
annexed project:
thank you
PS: I've made a quite large BOME mapping able to emulate higher resolutin messages out from traktor. Issue is now extending this to multiple devices.
https://maps.djtechtools.com/mappings/9279
cascaded maps.bmtp
2019-09-29 22:36:51
Hi, this can be done but not with Bome MIDI Translator Virtual Ports which are one way.
One end of a Bome MIDI Translator Virtual Port must be MIDI Translator and the other end needs to be a different application or a device (not MT Pro).
You can do it with Midi Yoke, LoopMIDI or LoopBE which are MIDI pipes if you would like, however this would be less efficient because a MIDI pipe performs 2 system calls for every message.
I would recommend instead to use the global variables in your rules to calculate the final CC message you want instead of creating 1 CC and then converting to another CC. Is there a reason, you need an interim CC message for this?
pedro.estrela
2019-09-30 19:04:15
please see above
pedro.estrela
2019-09-30 19:04:48
the reason is modularity and providing optional features to users.
I appreciate the BOME design choice of BMT devices being one way, as it avoids loops.
But could you please consider any solution for this avoiding yet more third party softwares? maybe using the MIDI router?
I ask this because I receive questions from users everyday about installation. Up to a month ago, I had a single traktor mapping to instal, and this was already painful; Now I have traktor+BOME; soon I will have Traktor+BOME+some_midi_pipe
this is an example of the issue people have:
https://github.com/pestrela/music_scripts/blob/master/traktor/ddj_1000_traktor_mapping/Installation%20Help/DDJ-1000%20-%20Installation%20and%20Verification%20of%20the%20two%20required%20mappings.pdf
thank you
2019-09-30 21:19:57
I will make your request. In the meantime, something like this might help.
There are 2 presets
  1. DDJ-1000 Native – MIDI message coming in here will handle your native mapping (with your rules applied)
  2. DDJ-SRX to DDJ-1000 – This will take input from a different source (in my case my DDJ-SB3 and set global variables ga for incoming MIDI channel, gb for incoming CC and gc for incoming value and then output a one shot timer “map cc to ddj-1000)
In the first preset, I added a translator (Special CC Mapping) with incoming value of the one shot timer ( my DDJ-SB3)
In the rules we look at the value of ga (MIDI channel) and gb (cc number) and then use rules to map to a different outgoing MIDI channel and number
I combined the channel and CC number to make the rules a bit easier for the mapping.
In this case I am mapping an incoming 14 bit CC into a separate outgoing 14 bit CC.
If there is no match, I exit with no outgoing action. This one translator allows for multiple CC mapping
I could have easily created different translators for every CC and just skipped outgoing action if the incoming values did not match what I wanted for that translator.
I hope you find this helpful!
DDJ-Special-Mapping-2019-09-30.bmtp
2019-10-02 18:50:53
Did this help? I DID make your request in addition to this workaround however.
Have you worked with the DDJ-SB2? I have one and cannot get the deck lights to light up. Everything else seems to work.
pedro.estrela
2019-10-03 17:15:28
thanks for the feature request.
the workaround definitively works, but i’m finding it increases complexity a bit, and leads to redundant code/translators.
using loopBE the performance decrease is marginal because this is for the pads
(the jogs still go directly)
i dont have an SB2, which has no RGB colors.
I have an SX2, SZ and 1000. All these support full RGB colors pads
2019-10-03 23:06:36
OK, thanks for responding. I was just hoping I could figure it out as Pioneer has not been able to help me with this. Glad LoopBE works for you in the interim although I DO understand the pain of having to load up yet another tool. I use this solution pretty extensively when I have a project for someone that I don’t have their controller. I end up first building a project using my available controller as a “emulator” for the target application I’m developing. Of course I rely on the documentation and the user to know if I got the emulation right. I just can buy every controller there is out there. If the target controller is cheap enough, I save the hours and just buy the target controller. (not very often though). Thank for your patience! Steve Caldwell Bome Q and A Moderator and Independent Bome Consultant/Specialist bome@sniz.biz
pedro.estrela
2019-10-04 00:11:30
On the SZ, you need to send something on “dj app connect” to light up the jog, and then send play and cue commands on channel 12 as well
https://github.com/pestrela/music_scripts/blob/master/ddj/1%20MIDI%20codes/DDJ-SZ1%20-%20MIDI%20Messages.pdf
There, the firmware will do the needle rotation, etc.
Please see my mapping on channel 12 to the exact commands going out
https://maps.djtechtools.com/mappings/9222
On the sb2 it only has documented the “dj app connect”. Maybe the other commands are the same
http://faq.pioneerdj.com/files/img/DDJ-SB2_List_of_MIDI_Messages_E.pdf
PS: my reason to move to BOME was to support the screens of the ddj-1000, as not even needle rotation is done by the firmware. This was a great success.
My objective is now backport the latest mapping to the SX2 as well, using the emulation method to merge everything in a single mapping
2019-10-04 00:21:48
Thanks! I missed that when reading the SB2 doc. I will give that a try.
pedro.estrela
2019-10-20 16:37:55
Added my BOME experiences to this seperate thread
https://www.bomeloft.com/support/kb/traktor-to-bome-experiences
pedro.estrela
2020-10-04 19:02:38
I've added this post to the advanced mappings index: https://www.bomeloft.com/support/kb/index-of-advanced-posts-and-tools
