madjazz
2019-10-01 05:24:12
madjazz
2019-10-01 05:24:12
2019-10-01 06:01:14
Hi Rick,
If your input buttons are momentary, it would look like this. You need a different global variable for each button
Incoming: Note on MIDI Channel 1 Note 112 velocity 127
Rule:
// Set default
pp=0
// Toggle global variable
ga=ga^1
if ga==1 then pp=127
Outgoing
Note On, MIDI Channel 1 Note 112, vel0city pp
Then do another translator for note 113 except use the global variable gb
(I’m assuming you are not already using global variables ga and gb anywhere else in the project.
Or if you want only one translator:
Incoming Note on MIDI channel 1 any note set note to pp, velocity 127
// Get global variable into local variable qq
if pp==112 then qq=ga
if pp==113 then qq=gb
// Toggle it
qq=qq^1
// Put it back where it needs to go
if pp==112 then ga=qq
if pp==113 then gb=qq
// set default
rr=0
// Change if 1
if qq==1 then rr=127
Outgoing: Note on MIDI Channel 1, Note pp, velocity rr
2019-10-02 18:39:54
Did this help, Rick!
ricleif
2019-10-02 21:36:19
ricleif
2019-10-02 21:37:14
Not sure yet — will attempt coding over next few days. Though, I am wondering: the problem here is that Touchable is not correctly latching the note by sending both a note on and off message in the same press (even though the UI element latches (that is, lights up and stays lit)? Is this correct, or is this standard behavior when using notes as controller input?
2019-10-02 22:56:46
Not sure on touchable. If it sends note-on for first press and note-off for second press, etc. then you should not need any rules in MT Pro.
The rules would apply only for momentary to make the behavior latching. As far as the Touchable UI lights, I’m not sure, but I think it should follow the behavior of the button.
Let me know when you get to testing it.
madjazz
2019-10-02 22:58:49
Yes, Touchable is sending both the note on AND off with each individual button touch. I’ve alerted them to the issue and they promise a fix in the next release. In the mean time, looks like I can correct this behavior through MTP. Will let you know what happens. Many thanks.
madjazz
2019-10-02 23:55:44
It worked! Awesome! Thank you!
2019-10-03 00:15:56
