yamahaqs300
2019-10-04 13:06:57
I receive from Korg ... CC 71 for example.And I need to execute to vsti with delay (0.3,0.5 seconds ) . I add delay to control....but nothing ...Any idea ? Thanks
yamahaqs300
2019-10-04 13:06:57
2019-10-04 14:45:24
Hi Florin,
Please post the project file or example file showing the problem and I will take a look.
2019-10-04 15:35:58
Hi, please see the example project file where I have an incoming note that triggers a CC with a 300ms (.3 second) delay.
yamahaqs300
2019-10-04 20:47:55
I did the same,like in picture,no delay .
2019-10-04 22:55:03
Could you post the log with the timestamp. You will notice the 300ms delay on the screen shot I posted.
yamahaqs300
2019-10-05 10:10:37
This is my CC …. I use the MIDI direct in paralel,but I block the control from Midi IN (from software) ,so the vsti receive only the CC from Bome
2019-10-05 15:23:55
The issue is you are looking for an incoming value of pp, however since pp is a local variable the value is not defined and could be anything. See first screenshot.
What you need to do is make incoming “any value” and “set value to pp”. Then you will get output delay. See second screenshot.
yamahaqs300
2019-10-06 12:26:12
Thank youuuuuuuuuuuuuuuuuuu !!!! I told you…..you are a God of MIDI !
2019-10-07 16:33:03
I’m glad we got it working!
