Delay notes in the range of D1 to D5
arturchernyshov61
2019-10-10 12:54:26
Hi! Tell me how to configure Midi Translator so that only notes from D1 to D5 pass with a delay of 10 ms. The rest should pass without delay. Thank you in advance!
2019-10-10 16:53:03
Hi, since MIDI has no note naming convention (different manufactures call the same note something else), I’m assuming we are using MT Pro naming conventions withe D1=note 26 and D5=note 74.  If you need to adjust for your DAW, then modify the rules in the translator accordingly.
Attached is the project file.
I created two aliases “My Input” and “My Output”.  When you first open your project file, assign them to the actual devices or applications you are using.
There is a default path between “My Input” and “My Output” in the MIDI routing section of the project. This means that anything that doesn’t have a translator will pass thru between these ports untouched.
Then I created one preset with incoming of Note-On Any note set note to variable pp and velocity to variable qq.
I then look at the note number and if it is out of range abort the translation:
if pp<26 then exit rules, skip outgoing action
if pp>74 then exit rules, skip outgoing action
Otherwise, I output the note with a 10 ms delay.
If you need to also delay note-off, you will need a similar translator for that.
I hope this helps!
Delay-Selected-Notes-2019-10-10.bmtp
arturchernyshov61
2019-10-11 18:48:01
Hi, Steve! Thank you very much for the help!
2019-10-11 18:49:07
My pleasure!
