bahamutx
2019-10-23 11:26:25
Hello,
can anybody help me with the correct MIDI messages for my ROLAND RD-2000.
I need to know how to Change the program, a.e. preset A03, or preset G12. MIDI channel would be number 1.
A-03 would be MSB 84, LSB 64, PC 3
G-12 would be MSB 84, LSB 65, PC 4
M-16 would be MSB 84, LSB 65, PC 128
In the MIDI implementation it is written that:
Program Change: Status: CnH, 2nd byte: ppH n = MIDI channel number: 0H–FH (ch.1–16) pp = Program number: 00H–7FH (prog.1–prog.128)
I also need to know how to change the Master Tune from a.e. 436.2 Hz to 463.0 Hz. This is done in the piano with the measurements in cents and the reference 440 Hz = 0 Cents.
This means 436.2 Hz = -15.0 Cents, 463.0 Hz = +88.2 Cents.
-----------------------------------------------------------------------------+ Offset Address: # 00 00 | 0000 aaaa | --------------------------------| 0000 bbbb | --------------------------------| 0000 cccc | --------------------------------| 0000 dddd |
Description: Master Tune (24 - 2024) | | -100.0 - 100.0 [cent] |
Master Tune "RD-2000_MIDI_Imple_eng02_W" p.9 (examples p.15 onwards).
I attached the corresponding PDF for you and hope that you can explain me how to calculate other values for myself.
Christopher
Master Tune “RD-2000_MIDI_Imple_eng02_W” p.15
Decimal and Hexadecimal Table In MIDI documentation, data values and addresses/sizes of exclusive messages etc. are expressed as hexadecimal values for each 7 bits. The following table shows how these correspond to decimal numbers. +------+------++------+------++------+------++------+------+ | D | H || D | H || D | H || D | H | +------+------++------+------++------+------++------+------+ | 0 | 00H || 32 | 20H || 64 | 40H || 96 | 60H | | 1 | 01H || 33 | 21H || 65 | 41H || 97 | 61H | | 2 | 02H || 34 | 22H || 66 | 42H || 98 | 62H | | 3 | 03H || 35 | 23H || 67 | 43H || 99 | 63H | | 4 | 04H || 36 | 24H || 68 | 44H || 100 | 64H | | 5 | 05H || 37 | 25H || 69 | 45H || 101 | 65H | | 6 | 06H || 38 | 26H || 70 | 46H || 102 | 66H | | 7 | 07H || 39 | 27H || 71 | 47H || 103 | 67H | | 8 | 08H || 40 | 28H || 72 | 48H || 104 | 68H | | 9 | 09H || 41 | 29H || 73 | 49H || 105 | 69H | | 10 | 0AH || 42 | 2AH || 74 | 4AH || 106 | 6AH | | 11 | 0BH || 43 | 2BH || 75 | 4BH || 107 | 6BH | | 12 | 0CH || 44 | 2CH || 76 | 4CH || 108 | 6CH | | 13 | 0DH || 45 | 2DH || 77 | 4DH || 109 | 6DH | | 14 | 0EH || 46 | 2EH || 78 | 4EH || 110 | 6EH | | 15 | 0FH || 47 | 2FH || 79 | 4FH || 111 | 6FH | | 16 | 10H || 48 | 30H || 80 | 50H || 112 | 70H | | 17 | 11H || 49 | 31H || 81 | 51H || 113 | 71H | | 18 | 12H || 50 | 32H || 82 | 52H || 114 | 72H | | 19 | 13H || 51 | 33H || 83 | 53H || 115 | 73H | | 20 | 14H || 52 | 34H || 84 | 54H || 116 | 74H | | 21 | 15H || 53 | 35H || 85 | 55H || 117 | 75H | | 22 | 16H || 54 | 36H || 86 | 56H || 118 | 76H | | 23 | 17H || 55 | 37H || 87 | 57H || 119 | 77H | | 24 | 18H || 56 | 38H || 88 | 58H || 120 | 78H | | 25 | 19H || 57 | 39H || 89 | 59H || 121 | 79H | | 26 | 1AH || 58 | 3AH || 90 | 5AH || 122 | 7AH | | 27 | 1BH || 59 | 3BH || 91 | 5BH || 123 | 7BH | | 28 | 1CH || 60 | 3CH || 92 | 5CH || 124 | 7CH | | 29 | 1DH || 61 | 3DH || 93 | 5DH || 125 | 7DH | | 30 | 1EH || 62 | 3EH || 94 | 5EH || 126 | 7EH | | 31 | 1FH || 63 | 3FH || 95 | 5FH || 127 | 7FH | +------+------++------+------++------+------++------+------+ D: decimal H: hexadecimal * Decimal values such as MIDI channel, bank select, and program change are listed as one (1) greater than the values given in the above table. * A 7-bits byte can express data in the range of 128 steps. For data where greater precision is required, we must use two or more bytes. For example, two hexadecimal numbers aa bbH expressing two 7-bits bytes would indicate a value of aa x 128 + bb. * In the case of values which have a ± sign, 00H = -64, 40H = ±0, and 7FH = +63, so that the decimal expression would be 64 less than the value given in the above chart. In the case of two types, 00 00H = -8192, 40 00H = ±0, and 7F 7FH = +8191. For example if aa bbH were expressed as decimal, this would be aa bbH - 40 00H = aa x 128 + bb - 64 x 128. * Data marked “nibbled” is expressed in hexadecimal in 4-bits units. A value expressed as a 2-byte nibble 0a 0bH has the value of a x 16 + b.
