using 2 MIDI-Controllers to control MA dot2 onPC
florian.soddemann
2019-10-25 00:04:18
i’ve got the following question, regarding the use of the APC Mini to control MA dot2 onPC: i want to use 2 Akai APC Minis sometimes and don’t know, how to do that. I got one APC Mini to work perfectly, but have no idea, how to use two.
In the future, i plan on using a Korg nanoKontrol or a Behringer X-Touch Mini in addition to one APC Mini.
I would be extremely thankful and happy, if somebody has an idea, how to “merge” two controllers into one output.
2019-10-25 00:33:22
Hi Florian,
Thanks for putting this question on a new thread!
The trick is to create input aliases for each and then define 2 separate presets with each preset looking for input on it’s device (overriding the project defaults).
For notes, you will likely have to convert note-off with velocity of 7F (APC-MINI default) to note-off with velocity 0
Since faders are on the same MIDI channels of notes, if you want to use them you will need to put them on MIDI CH 2 for your first APC-MINI.
For your second one, you should convert all note output to MIDI Channel 3 and fader to note on MIDI Channel 4.
Then send all your output to GMA2 as normal on a single MIDI port.
The attached should work.
You should assign The Alias APC MINI-1 to your first APC MINI and APC MINI-2 to your second one.
Assign the alias GrandMA to whatever port your are using in GMA2
The first preset has 3 translators.
The first one handles note-on with no changes.
The second one converts note off to output value of 0 instead of 127
The third one converts the incoming CC (fader) to a note and sends it out to MIDI CH 2 with the incoming velocity of the fader.
The first preset only monitors input from the Alias APC MINI-1
The second preset only monitors input from Alias APC MINI-2 and does the same thing with the following exceptions:
It translates all note-on and off message to go out on MIDI Channel 3
In addition to converting from CC to note, the outgoing notes are directed to MIDI channel 4.
I hope this helps!
2-APC-MIN-to-GMA2.bmtp
2019-10-25 00:34:42
Oh and now I see you are on dot2, yest it will work on dot2 just like GMA2.
2020-08-11 15:43:05
Ah, just found out that dot2 only allows for 1 MIDI channel so you will be restricted to MIDI CH1 and 128 controls so channel mapping will not work and you can only do note mapping and of course CC 2 note conversion on dot2. Steve Caldwell Bome Customer Care Also available for paid consulting services: bome@sniz.biz
